Avon Tires on my Fat Bob.. Pics
I really like mine also, I can lean in corners again.. I was glad to get rid of those knobbies.http://www.avonmoto.com/tech/tire-pressure-guidelines
You didn't look very hard. Go to http://www.avonmoto.com/ and select your make/model from the TIRE FINDER drop-down on the right side of the page. Recommended Fat Bob front pressure is 36psi; rear 40psi.
Can't speak to the first part, but the sidewall numbers indicate maximum pressure, not recommended pressure. I guess you should use their general guidelines then (from the link you posted earlier - it's not as specific though, so you'll need to experiment). Bottom line... you will need to run higher than stock pressure, even if you ride exclusively solo.
lol.. i guess i didnt look very well. thanks for the info
