Front end differences?
Old 04-23-2011, 01:36 PM
Down2Ride's Avatar
Down2Ride
Down2Ride is offline
Default Front end differences?
What are the exact differences in a Super Glide front end and a Wide Glide front end? Length difference? Rake difference? I have an 06 FXDCI and was wondering what a Wide Glide front end would do for me. Thanks.
-Marc
Old 04-23-2011, 05:40 PM
DCLXVI's Avatar
DCLXVI
DCLXVI is offline
The Wide Glide forks sit farther apart in the triple tree. Putting one on your bike would give you forks that are set farther apart. They are also a little longer because th Wide Glide has more rake from the factory.
Old 04-23-2011, 07:00 PM
howitzer88's Avatar
howitzer88
howitzer88 is offline
It will not handle as well, FYI. I'll stick to my narrow.
Old 04-23-2011, 07:10 PM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
Here is my 06 FXDI with a WG front end. I used WG trees with 3 degrees rake, my stock FXDI tubes, WG sliders, WG wheel.
Here is an older pic of the bike before the WG front end.
Old 04-24-2011, 09:43 AM
Down2Ride's Avatar
Down2Ride
jmpancoast-Looks Good! Are the stock WG trees 3 deg. rake, or did you order them that way? What did you do to chrome the lowers? Is that a 21" wheel? How did you have to modify the fender? Sorry about all the questions. That is the look I like. Just trying to figure out what I need to do. How much is the rear lowered?
Old 04-24-2011, 10:38 AM
TOMMAY's Avatar
TOMMAY
TOMMAY is offline
WG tubes with midglide trees,21x3.25 rim and 120/70 tire.
Old 04-24-2011, 10:55 AM
8541hog's Avatar
8541hog
8541hog is offline
Factory Wide glide trees are 2 degrees of rake.
Old 04-24-2011, 11:02 AM
dtech's Avatar
dtech
dtech is offline
4th Gear
jmpancoast that looks great I am looking to do the same to my 2000 FXD, I'm curious abotu your trees are they stock or aftermarket?
Old 04-24-2011, 04:42 PM
jmpancoast's Avatar
jmpancoast
These were aftermarket trees. I ordered them 3 degrees. As mentioned, stock WG trees have 2 degrees rake in them. The lowers are the Harley chrome sliders for the 06 and later WG. The wheel is a stock WG 21". I used my stock fender with 3/4" spacers on each side.
Search "WG" under my name. I have a thread with a lot of info.
Old 04-24-2011, 10:05 PM
Down2Ride's Avatar
Down2Ride
Cool. Thanks! Any difference in handling? Good or bad. Looks like this is what I'm gonna do. Just order the 3 deg. trees, chrome sliders, 21" WG wheel/tire...and use stock fork tubes. Oh yeah. Fender spacers.
Quick Reply: Front end differences?
