carb farts
carb farts
Hey I need some input here, my buddy brought me his 95 FXD he picked up 'cause it was leaking oil on top,he thought it was head gaskets. I put new rocker box gaskets in, no more leaks, but when I rode it for a test, it occasionally backfires through the carb. As far as I can tell the bike is all stock, and only has 16,000 mi. Plugs were really light colored, but the exhaust is black inside. When I called him he said oh yeah it's been doing that all along. Tomorrow I'll check for intake and vacuum leaks, I pulled the carb and cleaned it, anything else? I also put new plugs, stock ones for the bike
Evo's come directly from the factory with carb farts already installed (LOL). If its bone stock and its just an occasional thing thats perhaps a little worse when its really cold, then its nothing to worry about. If its worse than that, once you get it running and warmed up, spray the manifold where it bolts to the heads and check for leaks there. Thats were they most often occur. If it gets to the point it HAS to be corrected, switch to a Sportster needle and shim it up or maybe a thunder slide. Re jetting up to a 45 or 46 slow jet might also be a worth trying (42 is stock I think?????).
michaelbarry
07-18-2007 03:19 PM
