FXDF front end to FXWG conversion
You won't get the exact same look. The Wide Glide frame has more rake in the neck than the Fat Bob frame if I understand things correctly, since it's a different part number. There is some rake built into the trees as well, but not enough to give you the exact same look.
I do believe you can buy some aftermarket bearing cups that will give you the equivalent frame rake though. I'm sure someone else will have more information.
Just so you know, you're giving up some handling with that increased rake and skinnier front tire. Of course, you could always just go back to the dealer and work out a trade.
Sorry to jump here in the middle but I have a question. You state that the increased rake and skinnier tire will make it lose some handling..granted. But I have a 2010 FXDWG and the front end seems to wobble and bounce at speed(60 mph plus) or if I go over any difference of pavement at all. Now I am tall...6'4" at @250 with a lot of the weight and all of the height above my waist...kinda like a big sail. I can see where I could be the problem but what are your feeling about the rake and tire? Could it be an inherrant problem with them?
Don't get me wrong, the Wide Glide is not unsafe. It's just a different animal because of the narrower front tire and the increased rake. It will bounce around more and it will "hunt" more. If you're used to it you won't even notice it, but since the OP is coming from a Fat Bob with a 130 front tire and a short rake, it was worth mentioning.
What year is the FB?
How many miles are on it?
