2011 street bob thundermax speedo calibration?
With the latest version of SMARTLINK (2011.0.0) the speedo can be calibrated better than earlier versions of the software. Thier is now a speedometer calibration calculator. It allows you calibrate your speedo via tire diameter, pulley data, or speed indicated speed vs. true speed.
I used my GPS to check my bikes speedo and found that my speedo was 10% slow. The GPS said 55mph and the bike's speedometer was 50mph. The Speedometer Calibration Calculator came up with 41727 from the default of 45900 for a speedo calibration on my 2007 FXDL with a Perilli Night Dragon 180/60/17 tire on the rear. I checked my speedometer with the GPS after the change and the speedometer is spot on at any speed.
Guys I'm resurrecting this post..................
I need to calibrate my speedo since I have the 30t front and 70t rear. Instead of using the GPS I want to enter original pulley tooth count of 67 and new size of 70, BUT there is no option to enter front pulley size of 30! How will thundermax know to get the right speed? Does the rear pulley dictate this entire speed calibration measure?
2011, bob, caibration, calibration, davidson, digital, dyna, harley, installing, max, speedo, speedometer, street, thunder, thundermax
