Ignition relocation custom build w/pics
Old 07-06-2011, 09:26 PM
128auto's Avatar
128auto
128auto is offline
Default Ignition relocation custom build w/pics
I had a post a couple weeks ago about key fob rubbing the frame, I do a little research here and there, end up doing my own ignition relocation. What parts do I need? Basically I only bought a switch from Phat performance parts, drag specialist part number DS272187, costs me $31.95, I found a car coil over spring aluminum plate kicking around my shop, cut it in shape, file and smooth the edges, paint it flat black and tap some threads for mounting the switch. I cut the top engine mount bracket a bit and make a mounting hole.
Old 07-06-2011, 09:37 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
Looks nice and much cleaner without the cowbell.
Old 07-06-2011, 10:39 PM
8541hog's Avatar
8541hog
8541hog is offline
Nothing like fabbing your own parts. Nicely done.
Old 07-06-2011, 10:49 PM
gartec81's Avatar
gartec81
gartec81 is offline
looks real nice. good job
Old 07-06-2011, 11:07 PM
HemiOrange's Avatar
HemiOrange
HemiOrange is offline
Very nice and clean job!
Old 07-07-2011, 12:22 AM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 3,940 Likes on 2,295 Posts
Sweet! I like the cowbell, but I believe I like that setup even better. Nice work!
Kevin
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
Old 07-07-2011, 05:40 AM
blueangel73's Avatar
blueangel73
blueangel73 is offline
I do believe you found yourself a part you can make and sale. That is a very clean look and just what I have been looking for. Now to find me some parts to cut up.
Old 07-07-2011, 07:53 AM
128auto's Avatar
128auto
128auto is offline
It isn't hard to find something to cut up, you can get any 1/4" steel or aluminum plate, trim to the shape you like, it doesn't have to be round but I think round looks better than square. Get a 2 1/4" hole saw and a little bit of your own time, you're done. I recommend aluminum cause it is easy to cut, grind and file. Good luck!
Old 07-07-2011, 08:25 AM
Cowpokey's Avatar
Cowpokey
Cowpokey is offline
That's cool, but what did you do with the horn? I took my key fob and attached it to a wallet clip, then wove a "key chain" for the key out of some 3mm (or smaller, maybe 2.2mm...don't remember) cordage. Just hang the fob from a belt loop. The powedercoat on the neck of my frame has marks from the fob rubbing on it, but its not getting any more.
Attached Thumbnails Ignition relocation custom build w/pics-key.jpg
Old 07-07-2011, 08:29 AM
06hdsb's Avatar
06hdsb
06hdsb is offline
Nice clean look.
Quick Reply: Ignition relocation custom build w/pics
