Fuel Pump Noise
Fuel Pump Noise
Normally when I turn my 06 Dyna's kill switch on, I get the faint whir of the fuel pump running until the lights go out and it's ready to start. I've noticed a few times that the pump noise is much louder than usual. It doesn't do it all the time, just once in awhile. Bike is running great and there aren't any codes or lights. Anyone else ever notice their pump periodically making more noise than usual while priming before start?
RE: Fuel Pump Noise
I have heard the same weird noise from the fuel pump on my bike and my friend has the same issue with his. Apart from the recall for the tranny, primary inner bearing, fuel injectors, flickering neutral light, noisy rear disc brake when cornering (even though I am not touching the brake pedal), noise from the drive belt, plus a front end clunk every time the front brake is applied, it's running great. What could possibly go wrong?
RE: Fuel Pump Noise
The fuel pump always makes a little noise. The part that disturbs me is that mine now makes an intermittent hissing noise from the fuel pump and for some reason......I have had issue with the when my fuel light comes on and the thing runs out of gas. I will be running out of gas the minute the freakin light comes on!! Starts to pop and die on decelleration. Sound about like what anybody else is experiencing?
RE: Fuel Pump Noise
[:-] My fuel pump sounds like it could die sometimes the noises it makes! I only have 4500 miles on my bike!
ORIGINAL: truenorth
