Evil Apes on a 2011 Wide Glide Help
Old 08-08-2011, 10:03 PM
shafferk's Avatar
shafferk
shafferk is offline
Default Evil Apes on a 2011 Wide Glide Help
Ok guys, I've done a search but can't seem to find the answer I'm looking for. Here's what I'm doing. 10" Black Carlini Evil Apes, 1.5" risers, Aeromach levers, Joker Machine fork mounted astro turn signals and rear Joker astro turns signals...all at once. My question is this: will I have enough cables and wire to install the bars without replacing them? I'm about to dish out $1000 not including shipping and I'd hate to have to spend more $$$ on cables and wires. I looked at it tonight and the only line that looks like it might not be long enough is the brake line but I'm not sure. Any insight you guys can give would be much appreciated. Thanks.
Old 08-09-2011, 01:15 AM
paulies 07's Avatar
paulies 07
paulies 07 is offline
If your running stock bars, yes
Old 08-09-2011, 08:58 AM
WG2011's Avatar
WG2011
WG2011 is offline
I have 9" carlini clean sweeps and was ok with wires and cables but it was very close but its golden ended up just perfect. If I had to guess I think your going to have to switch cables, wires would probably be ok cause theres alot of extra slack from factory there. Maybe call carlini directly ask them what the difference in height and pull back is between the 9" clean sweeps and your evil apes and you will probably have your answer. However with the risers and being the bars are also an inch taller than mine I am fairly sure cables won't work. Good Luck
Old 08-14-2011, 07:23 PM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
I'm installing 10" evil apes right now and had to get new cables, not a dyna but not sure how much you have there for slack in the cables
Old 08-17-2011, 09:40 PM
shafferk's Avatar
shafferk
shafferk is offline
In the end, I decided to go with the 9" Clean Sweeps. It's just easier and they'll handle better. I'm not sure what I was thinking, lol...
Nickdawg18
04-10-2013 02:50 PM
jasonleahey
01-05-2013 08:32 PM
WideGlideRide011
08-09-2012 08:58 PM
CB1
11-15-2011 03:12 PM
arrowslinger1980
12-14-2010 12:40 PM
Quick Reply: Evil Apes on a 2011 Wide Glide Help
