Tmax, results
Tmax, results
I installed a set of cams in the bike, i used a basemap on the recomendation from Zippers,
My thought was that it was a considerable mismatch to my setup,,,, 06 88" two into one exhaust, redshift 557 cams high flow ac, stock heads, 25 degree injectors,
The map is for a 95" ported heads, dual exh, 557 cams...
Ran the bike about a 100 miles and checked on the correction, to my suprise the Tmax made the corrections and still didnt recomend an Auto tune???
Im Sold on the Tmax.. Bike runs great....
Although i still want a 95" with a reworked set of heads and more cam, it will due for awhile,,
I would only disagree in regards to saving the updated map for future reference. When you automap you can create a new map and save it should you ever need to reset. In that regard it is a good idea to run and save after 4-500 miles so it has had plenty of time to fine tune. Even after that much mileage you may notice a very slight improvement as it begins the process over again.
Funny that you say that, the front cyl was good, with no recomendation for auto map, the rear made a few more corrections, it said (recomend) automapping, I will watch it for awhile and see where it goes..
Bike seems to run cooler with the cams!!!! Although its been freakin hot here in CA.....
One of the things I like about the TMAx is the ability to access the data collected by the unit ... I downloaded a bunch of it to my laptop and did a little manipulation with Excel spreadsheet and graphing ... see https://www.hdforums.com/forum/dyna-...-and-data.html ....
Welcome to the TMax club ....
R/
'Chop
R/
'Chop
