How do i WHEELIE my FAT BOB?????
08-29-2011, 04:35 PM
Quote:
Originally Posted by
paul s
Did you do anything for raising your compression with those cams? The 45* Intake close on them bleed off a bit of compression making for a softer bottom end. I have 37's advanced +4* for a 34* IVC, with my .030HG I'm at 190 CCP. I think the SE 204's are better than 211's for all else being stock.
idk my mechanic did the work, i just stand and wheelie on my bike. and ride hard
08-29-2011, 04:50 PM
It's easy to run a compression check, it will tell you where you're at, if you're cams only it will be a low compression build with a 45* IVC.
08-29-2011, 04:52 PM
why a wheelie? its a harley. thats what street bikes and dirtbikes are for. all fun and games until you blow out those lower fork legs.
08-29-2011, 04:56 PM
06redneck
Thanks for your concern but how about you read my post again.
08-29-2011, 04:57 PM
Next topic will "how to snap a belt on my fat bob" or "How to twist a crank on my fat bob". Its your bike and at least your having fun on it!
08-29-2011, 06:31 PM
I would try the bounce method mentioned previously. I think the biggest issue is that nearly solid front wheel. That has to be heavy.
08-29-2011, 06:36 PM
Put more power into it!!
Bigger motor!! WOOT WOOT!
Be careful man!
08-29-2011, 06:48 PM
the trick is use a little rear brake but you have to really watch out, make sure you have someone running a video camera you just might make it on TV.
08-29-2011, 06:57 PM
Here is the trick...
1. Sell your bike.
2. Buy Crotch Rocket
3. Name your new Crotch Rocket "Fat Bob"
4. Do a wheelie
The following 2 users liked this post by Glock Enthusiast:
08-29-2011, 08:07 PM
06redneck
All this time I thought a Harley WAS a street bike.......
