Help! Check engine light coming on! :(
Hey guys,
Ok, so for some weird reason, my check engine light is coming. However, it only comes on for a few seconds. When I hit the run switch, the check engine light always comes on along with the 2-3 second beep. Normal. Every harley does it. But, after it goes away, about 3-4 seconds later, the check engine light comes back on and stays on for about 7 seconds.
Any suggestions on what the heck its doing that for? My bike is running completely fine, and I've had no troubles with it (at the moment). Should I run diagnostics on it and see if it'll throw codes?
If so, does anyone have the link to the page to run diagnostics and codes? I had it saved on my old computer, but it crashed a while back and I lose everything.
Thanks fella's,
Adrian
Thanks fella's,
Adrian
It's telling you it has a stored code from a previous problem or an intermittent problem that clears itself. After a few starts an intermittent problem light will go away if problem goes away but did not know it cleared stored codes on it's own. Ought to read it before deleting.
Hey guys,
Thanks fella's,
Adrian
Thanks fella's,
Adrian
Been some time...hope you and the family are doing OK in FLA!
+1 on what grf000 posted.....
Here's the text from my 2003 Dyna Models Electrical Diagnostics Manual for you Adrian:
"1. When the ignitions witch is turned ON, the check engine lamp will illuminate for approximately four seconds and then turn off.
After lamp turns off after being illuminated for the first four second period, one of three situations may occur.
a. The lamp remains off. This indicates there are no current fault conditions or stored functional trouble codes currently detected by the ignition module.
b. The lamp stays off for only four seconds and then comes back on for an eight second period. This indicates a functional error code is stored, but no current trouble code exists.
c. lf the lamp remains on beyond the eight second period, then a current trouble code exists.
3. See CODE TYPES which follows Íor a complete description of trouble code formats.
NOTE
Trouble codes relating to the ignition coil can only be fully diagnosed during actuation. For example, a problem with the ignition' coil will be considered a current fault even after the problem is corrected, since the ignition module will not know of its resolution until after the coil is exercised by vehicle start sequence. ln this manner, there may sometimes be a false indication of the current trouble code.
CLEARING CODES:
After correcting system problems, clear trouble codes using the Scanalyzer. If the Scanalyzer is not available, perform 50 start and run cycles. To execute one run cycle:
1. Start vehicle
2. Let it run for at least 30 seconds
3. Turn the engine off"
