LED tail light (What to expect)
Has anyone installed a LED tail light and or rear LED turn signal on their 07 Dyna I have the turn sig harnessed in with running lights ( what to expect and any additional purchases to install is the question )
Looking to do this as a winter project, the dumb a$$ behind the counter at the stealer was totally clueless so HD OEM is out have to go after market
Thanks in advance for any info
D/C
D/C
www.customdynamics.com
They have everything you need. Good stuff, good warranty, quick service. I already had the HD LED tail light, but converted my turn signals to RBT.
I don't understand why this simple swap could be considered a winter mod. It doesn't matter if you are changing the turn sigs to run/brake/turns with LEDs or just adding a load equalizer to convert 1157's to LEDs, the worst case scenario will still take well under a half hour to accomplish. It's plug and play.
