Could someone look up a torque spec FXDF
Old 10-14-2011, 10:32 PM
catalac's Avatar
catalac
catalac is offline
Default Could someone look up a torque spec FXDF
Hi Guys
2009fxdf fatbob
Could someone help me out, I had to remove the rear caliper housing and guide/float pin. I need the torque for the bottom 40 hex bolt that holds the caliper to the axle piece and the guide pin 40hex which allows the caliper to float at the front of the caliper.
Thnx
Old 10-15-2011, 12:47 AM
jp28's Avatar
jp28
jp28 is offline
Default torque values
Axle Nut: 95-105 ft-lbs
Slider Pin: 10-14 ft-lbs (same as caliper mounting bolt)
Attached Thumbnails Could someone look up a torque spec FXDF-rear-caliper.jpg
Old 10-15-2011, 09:57 AM
catalac's Avatar
catalac
catalac is offline
Very good, thanks.
MyFavRk
02-10-2019 06:49 AM
Shadowray
2014-2023 Touring Models
11-01-2015 11:36 AM
splattttttt
07-06-2015 02:48 PM
yowflhtk
Wheels/Tires
09-21-2012 08:10 AM
roadglide80118
07-28-2007 09:25 PM
Quick Reply: Could someone look up a torque spec FXDF
