SE Super Tuner
When you bring the bike in for dynojet tuning, hand your dealer a flash drive so he can put a copy of the final tuning program on it. If you have additional tuning done elsewhere later on, I think you will need a copy of the program along with the SEPST or else you will have to start all over.
I just went through this with mine. He is correct. If you have mechanical issues with your bike, you will need it. I just keep mine in the saddlebag or somewhere on the bike when I am traveling in case something happens. Second, you need to find out if the dealer ordered you cables with the race tuner or not. They run about $50.00 and if they did, you need to get them and if they didn’t no big deal. They only need the race tuner when tuning the bike. You should have also gotten a print out of your new numbers from the dyno tune. I have the same wire capped behind my air cleaner and also was told it has to do with the old air cleaner and not to worry.
Yup, you have the setup stored in the bike's ECU and a copy on the SEPST, so little chance you'll lose your tune. Once you get your cable and software you can make a further backup on your PC before messing with it.
mikepett
04-13-2011 08:41 PM
