Completely draining 2012 Fatbob fuel pump
Old 11-21-2011, 07:07 PM
Paulflhx's Avatar
Paulflhx
Paulflhx is offline
Default Completely draining 2012 Fatbob fuel pump
I had to drain the gas tank to get it painted. No problems until I couldn't get the last bit of gas out. It remained in the fuel pump. I did what the manual says , to pull the plug on the fuel pump , start the bike, and let it run til it dies. Problem was, the bike wouldn't start at that point. It cranks but sounds like it's out of gas, which seems normal since I drained the tank, but this procedure was supposed to make the bike run for a little while, using the gas in the fuel pump. It didn't use that gas. I then went into the tank and pulled the hoses off the fuel pump and drained that gas out, but it still smells like there is some gas hiding in there somewhere, a day later, and after I used my compressor to blow air in it to displace gas fumes! Any idea why the bike didn't use the gas in the fuel pump lines? Does the 2012 pump only allow gas to flow through it when it is powered?
Old 11-21-2011, 07:13 PM
South Jersey Scooter Trash's Avatar
South Jersey Scooter Trash is offline
Why are you painting already?
Old 11-21-2011, 07:18 PM
Paulflhx's Avatar
Paulflhx
Paulflhx is offline
black shows too many scratches and swirls. Drives me crazy.
Old 11-21-2011, 08:17 PM
08fxdf43202's Avatar
08fxdf43202
08fxdf43202 is offline
Ummm.... remove the pump from the tank and the gas that is in the pump will come with it?
Old 11-21-2011, 08:35 PM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
Don't know how different the pump is on a 12' verses my 05, but the pump comes out in a minute.
Old 11-21-2011, 08:47 PM
Paulflhx's Avatar
Paulflhx
Paulflhx is offline
Well, I know I could remove the pump and solve the gas in the tank problem, but I really wanted to know why, after following the service manual, it didn't drain the fuel pump.
2500hdon37s
08-26-2014 04:00 PM
KJB
04-30-2014 01:58 PM
tambob10
09-07-2012 01:16 PM
Bushy
07-27-2012 02:53 AM
Sargergp
06-21-2011 03:18 AM
Quick Reply: Completely draining 2012 Fatbob fuel pump
