crank position sensor
Old 06-04-2016, 08:20 AM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 5,538 Likes on 3,031 Posts
Originally Posted by creepychicken
Hey There,
I know this is an old thread, but I've searched the internet for a while now to find what the hell's wrong with my bike. I have a 1999 FXDWG, and the same problem that you had with yours has been happening to me, however, I am able to start it back up after leaving it sitting for a while. Anyway, I've changed numerous things and worked on others to resolve the problem and even taken it to a few mechanics with no luck. I just ordered a crank position sensor and plan on changing it out tonight. Did you change yours out yourself? Is there anything special about the installation or is it just plug and play? Any info you can offer would be greatly appreciated, so thank you in advance. I hope to hear from you. I'm at my wits end with this **** and really hope this works!
Thanks,
Liz
That dude hasn't posted in 5 years. Chances are he isn't going to answer your question. Start a thread in the engine tech section. Those boys should be able to help.
Old 06-06-2016, 02:59 PM
creepychicken's Avatar
creepychicken
creepychicken is offline
Stage II
Things have been so hopeless as of late,I thought I'd try it out. Thanks for the suggestion!
Old 07-06-2018, 11:18 AM
tracybabytaylor@gmail.com's Avatar
tracybabytaylor@gmail.com is offline
Stage II
Originally Posted by Bubba Zanetti
Same thing happened to my 2002 FXD. Only instead of just dying suddenly, it spit and sputtered for a few seconds, then died.
do you know where the crank positioning sensors located on a 2002 Dyna Low Rider
ush1000
04-03-2019 04:48 AM
Vrodjoe
09-19-2016 07:39 PM
LonewolfFrank
11-15-2015 08:00 PM
hungoverdog
05-25-2012 11:01 AM
twistedcherokee
03-21-2011 11:21 PM
Quick Reply: crank position sensor
