Fat Bob exhaust swap out help
Anatomy of the stock muffler
Ok, I've taken the mufflers off and apart. There's a long baffle, like maybe 20", as long as the muffler exterior. As exhaust enters the baffle it hits a solid wall forcing the gases thru the baffle wall, thru five layers of fiberglass wrapped around the baffle, then back into the baffle on the other side of the wall, and then out a small outlet. No wonder it's so quiet.
I am taking the V&H off, putting the stock exhaust back on WITHOUT the fiberglass wrap. I'll see how that sounds. If not acceptable I'll take the baffles out (that will be too loud), and then I'll start to modifying the stock baffles. If I don't get a good result, I'll try the QQ baffles in either the vance and hines or the stock system.
I may have a set of big radius for sale soon.
I have the 4 1/2" oval Cycle Shack slip-on's on my Fat Bob and couldn't be happier. Look good and sound great while allowing you to adjust the flow for tuning by bending a tab in the baffle. Top notch all the way around!
Over the years many have tried drilling and found the sound less than satisfying (like a lawn mower). Removing the wrap will be worse. Nothing substitutes for a properly designed baffle system. You may want to search the forum for ideas, there was a decent thread maybe a year or so ago.
