***Dyna Models & General Service Video Link Index***
Gonna launch this idea which I had in the "hold" mode for a few months...
Any additions are welcome & much appreciated: just post the video clip over here and I'll add the link to the index.
AMP connectors disassembly part 1
posted by mud 10-09-2010
AMP connectors disassembly part 2
Bleeding brakes
posted by jangler14 01-22-2013
Cam replacement
posted by Sahs302 12-25-2011
Club Bar Install
posted by bootleg 10-20-2010
Clutch adjustment
posted by blacknsilver 04-08-2012
Clutch cable removal
posted by zimm 02-25-2013
Change primary fluid and adjust primary chain (How to...)
posted by Wide Glide Bry 10-07-010
Deutsch connector disassembly
posted by SC-Longhair 06-03-2009
Fall-away check
posted by treadstone 03-15-2012
Flush mount fuel gauge install
posted by tomt 05-11-2012
Front fork slider tubes (How to replace...)
posted by Dirknar 01-20-2012
Handlebar Grips (How to replace...)
posted by Benway 12-15-2011
Handlebar Grips (How to remove glued...)
added Dec 6-2012
Handlebar & wiring install video
posted by R_W_B 03-29-2012
Oil Change on a 2003 Harley Davidson Dyna
added April 7-2014
Spokes & fall away (How to check)
added March 16-2012
Miscellaneous:
2014 Dyna Models torque values
added March 27-2013
Bleeding brakes
Cam replacement
Club Bar Install
Clutch adjustment
Fall-away check
added Dec 6-2012
added April 7-2014
added March 16-2012
Miscellaneous:
added March 27-2013
cam replacement (video)
Here's a new addition to the index.
This video was posted 12-25-2011 by forum member Sahs302:
hey fellows, i come across this video and i thought that some of you might want to see this enjoy.
http://www.youtube.com/watch?v=n5KvamRqCis
Posted by R_W_B March 29-2012:
I use a shop vac to suck a string in. Takes about 1 second after you tape off the other holes. I put TBars on which are the hardest to get past the 90* turn so I only pulled 4 to 6 wires at a time, went smooth then.
I made a video back when I did it.
http://www.youtube.com/watch?v=-vkoq6kLlqw
Clutch adjustment
New addition:
I loosen my clutch cable first then adjust the clutch pac by tightening until I reach resistance then backoff 1/2 turn then tight lock nut. Then adjust the clutch cable. Also should do the clutch pac adjustment while the motor/clutch it is not hot. Here is a good video
http://www.youtube.com/watch?v=Qw6da27b1w4
Flush mount fuel gauge install...
...by tomt starts at 20:29:
http://www.youtube.com/watch?v=44ArT...ature=youtu.be
The video starts Tom showing us how he did his WG tank conversion.
Thanks for sharing, Tom!
