Switchback vibration
You 3000 rpm guys must have very liberal laws in your state. On my SB at 3000 rpm's in sixth gear I'm doing over 80. Now on the way back from Daytona a bolt did break off in the exhaust mount the dealer is researching that. They are going to fix all the problems that came with that. On that trip I have to admit I was running 75-80 most of the way. But the vibes weren't that bad until after the exhaust bolt came loose. Then it was real bad. Now I'm at 5300 miles and growing.
awesome Huh?
naw they're real good for turning thier heads , just bitch it'll get done.. some dont have a vibe problem..
Probably not but if its something weird then 5 years from now people will say "stay away from the 12 switchbacks" like they now say "stay away from the 06 Bobs" Risk you take when you buy the first year of a new model....especially with HD where the public doubles as the R&D department. It's a fact that HD first year models have a terrible track record. First year Evo's, first year Low Rider, first year V-Rod, the 06 Bob..........those are the only big ones that I can think of without googling.
I don't know if it will help in this case but here is how I cut done on the vibes from my exhaust.
- Loosen the mounting bolts except at the exhaust flange and muffler clamp.
- Start the engine, let it idle, and give it a couple of revs.
- Shut the engine off and retighten all the mounting bolts.
This drastically cut down on the vibes I was getting in the right footpeg.
I test rode a SB when they first came out and it vibrated hard at all speeds, esp. at 70 -80mph. The bike had just over 125 miles. When I returned to the dealer I spoke to a guy who had ridden the same bike earlier in the day and he too complained of the vibration. Three weeks later I was talking to the service manager of another Harley dealer and he told me the Motor Company was aware of the vibration problem and was going to issue new (apparently softer) motor mounts to quiet the shakes. The SM thought this would be a warranty issue, not a recall, and that SB's assembled later in the production run would come from the factory with the latest modified mounts.
but as i said, i hit 200 miles of babying this past weekend so i ran it up to 3k in 6th gear and while at a steady 3k on the highway which was right around 80mph for about 3 miles i had a non stop vibration through the whole bike, this will definitely be disconcerting/uncomfortable on a long trip.
the claims of the problem being with the 2-1 factory pipe has come from
a lot of internet searching and found on multiple sites and this is why i had asked if anyone experienced the vibrations and then they went away with a slip on change.
for you guys that dont feel any vibrations at all,
did you have the new pipe installed before it left the dealer?
lol, I'm an exception, you got that right, and if you look back through my posts , since i aquired Ruby, i have always stated this , and yes , i think its mount related, cause its like butter before and after..and actually, at 80+ it's teeth chattering. bikes going back to the dealer as soon as the weather turns nasty here, been lucky still having some great days to putt.. 4300 miles since mid aug..
no doubt it will get figured out.
this is my usual range also, 2300-2500 is right around 65 to 70mph
teeth chattering is putting it mildly..... but even with the BAD vibration i am in love with this bike and have
