Screamin' Eagle 120R engine for Dyna
Welcome to my world. Installed an SE 120R in my 06 Street Bob last spring. Last summer was a lot of fun, can't wait for the roads to clear and spring to come so I can start riding this thing again.
It will be interesting to see how the 408-6 produces.
The dyno sheet from my bike. The main difference in this build from others. SE roller rockers, Latus / Baisley throttle body and manifold with V rod injectors, VH pro pipe hi output. For clutch am using SE kevlar plates with SE diaphragm spring and AIM VP 92c variable pressure clutch.
Went with a Wood 408-6 which is said hits hard early early......it did on my 103 build, where it hit 100footlbs at 2500rpm. Anyhow, we'll see when it hits the dyno.
Couple question since I just ordered mine.
Why change the value springs?
What clutch?
Did you weld/ true the crank?
Mine will be carb'ed so that will be different
You got ne thinking about the cams...
What clutch?
WOW! those are great numbers on your dyno sheet. I chose the Hi output ProPipe as well since my current FatCat wouldn't flow right for the 120. Thought about those VRod injectors, but used a "lesser" SE injector set.
