Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Sign in using an external account
Register Forgot Password?
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, FXR Super Glide, Dyna Glide Convertible, Super Glide T-Sport, Dyna Glide Police, Dyna Switchback, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Featured Articles:
Riding a motorcycle provides all sorts of pleasures (and pitfalls) that you just...
Read More
Peter La FranceBarnett's MagazineOne of the most anticipated and dreaded Harley...
Read More
(In)Famous ex-football coach Bobby Petrino has put his Harley Davidson up for sale...
Read More
P
Thread Tools Search this Thread
Old 02-09-2012, 03:06 PM
Prodriverdon's Avatar
Prodriverdon Prodriverdon is offline
Garage is empty, add now
Default Need input on engine upgrades
Thinking of putting in the following into my 2006 SB TC88, Headquarters #0039 Cyclone cam,Compensator Kit,Performance Clutch,Diaphragm Spring,EFI Super Tuner Kit,Cam Drive Gear Reten,Cam Plate Support Kit,Tappet Lifter,HD Quick Install Pushrods,Cam Service Gasket Kit. I want to also change the intake but the Heavy Breather hits my knee and would need another style. Anyone else that has done this let me know how you liked the changes or should I do more. I am staying with my V&H SSS Exhaust. The local Dyno tuner said I would be better off with a 2-1 system but I like the look. My riding style is 0-90 and then cruise at 70. I only have 7K on the bike. I want better throttle response. TY in advance.
Old 02-09-2012, 03:31 PM
MADDOG187's Avatar
MADDOG187 MADDOG187 is offline
you must have a massive wallet if your going to do all that just to get better throttle response , all you need to do is throw in a K & N free flow air filter and get your carbs re jetted , job done and very cheap.... , maybe a set of slip on free flow mufflers , and you,ll be singing ,
that will more than do you to 90 mph , and cruise at 70 , who,s giving you the advice ....? is it the guy who will be taking all the money off you ?
now if you wanted the fastest bike on your block ...thats a different matter
sorry i missed the fact its an EFI , do the super tuner instead of the jets ....lol
Old 02-09-2012, 04:11 PM
JRK5892's Avatar
JRK5892 JRK5892 is offline
Sponsor
Drop a power pulley on it, that will make night and day diff for you, also SE or barnett clutch spring... what are you running on the bike now (intake/pipes/tuner) ... mad dog he has a 2006 so he has EFI,
don depending on your tuner you may also want to look into 12* injectors step up form the 8* we got in our bikes... but depending on the tuner you can compensate for this...
__________________
The Powder Pro
*street bob 100% powdercoating, 0 paint*
http://i47.tinypic.com/r8xk6t.jpg
www.thepowderpro.com
Joe Knapp, Chicago IL
Custom powdercoating work, fork bag stereo's, and much more
95', Welded & trued crank, lefty bearing, Heads by WFOLarry, andrews 37 cams, Andrew's 30T power pulley, 70t rear pulley, barnett clutch spring, tapered pushrods, flat top pistons, lockhart oil cooler, steering damper: 94HP and 98TQ
Old 02-09-2012, 05:05 PM
hboat hboat is offline
Prospect
I've learned so much from this forum...and most here know more than I, but I'm a huge fan of a 30 tooth primary sprocket...peps the bike right up. I geared down my 1200S and all my Triumphs back in the day.
Try it, you'll like it.
__________________
'07 StreetBob.
SE slip-ons (always liked 2 into 2), RSD A/C, Tuning-PowerVision-Fuel Moto,
Fuel Moto street port-9.8 CR, Andrews 37, 30t/70t, Barnett clutch w/ SE Spring,
True-Track, Progressive 440's and forks. I'm done...for now.
Old 02-09-2012, 05:53 PM
ian03xl ian03xl is offline
Hang Around
A free flowing intake and exhaust and a good tuner with a dyno tune from someone that knows what they are doing will deliver enough power to satisfy your riding style. The cam stuff is a nice upgrade from the chain drive stockers and the clutch stuff is just a waste of money on an otherwise stock engine. Don't waste your money on unnecessary parts.
Old 02-10-2012, 08:50 AM
JohnC FXDX's Avatar
JohnC FXDX JohnC FXDX is offline
That is too much cam for a stock engine. That cam wants a lot more compression, more displacement, head work and maybe bigger springs. I forget the lift specs on it, but isn't it like .590? If you are set on a HQ cam, look at the 0034. Otherwise check out an Andrews TW37. With a stock motor you want to keep your intake close below 40*. The lower the more torque. Since you like the 0-90, closer to 40 will be ok.
Old 02-10-2012, 09:42 AM
RICHIEMACK's Avatar
RICHIEMACK RICHIEMACK is offline
RICHIE MCKENZIE
Waste of money without head work.also that cam is to big..tw 36 or 37 would work as john said,also se cam plate since its already going to cost plenty you might as well go all the way,clutch spring???
__________________
06 NIGHT TRAIN ,95,big bore .BASSANI ANDREWS 37G,,48 MM,TBODY.DK. CUSTOM,JOKER, ART ALLOY,SE.,RIVERA,422'S,FLAT TOPS.ADJ.SE. PUSH RODS.SE.RACE TUNER.OIL COOLER,SE CAM PLATE
95 HP 96 TQ BIG BOYZ HORSEPOWER INC.
http://s1087.photobucket.com/albums/...HIEANGELA2010/
Old 02-10-2012, 09:59 AM
07bobber's Avatar
07bobber 07bobber is online now
just do a cam, ac, tuner and dyno it should be more than enough...............im looking at the woods tw6-6
__________________
21" Front wheel, Works black trackers, Race tech Spring & Gold valve emulators, Superbrace, Lyndall Racing Z+ pads, D&D Fatcat, C&C fastback, Hogrida laydown plate mount, Vrod fairing, 12" westcoast t-bars, PM grips, Ness mirrors, AZECE.com point and AC covers, Dakota Digital speedo, HD flush mount gas cap and guage, lots of black powdercoat
Old 02-10-2012, 01:18 PM
bigVtwin88's Avatar
bigVtwin88 bigVtwin88 is offline
Prospect
Send a message via AIM to bigVtwin88
If it's an 06 you might want to spend some money on a new inner primary bearing before all the go-fast stuff. I've never messed with cams myself, but I think there are end-play issues with the crank when you switch to gear driven cams.
__________________
04 FXDWGI
Old 02-11-2012, 11:33 AM
THX for the all the info. No,I dont want to waste $ but want to do everything at once. Maybe I should go all the way and have and have it ported ,polished,balanced,primary bearing,etc.I am going back to the drawing board..... By the way TY to Surdyke HD because they are saving me big $ on parts.
P
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
Sponsors
Advertising Information - Harley Davidson Forums - Archive - Top
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Admin, Emails & Contact Details
