Saturday install complete. Hard bags.. 56k beware
1960's sportster hard saddle bags.
fiber glassed inside for reinforcment
piano hinges on the sides so they open away from the bike
cam locks (allens ) for the locking mechanisms
still need to get them painted. faded fire truck red is just not doing it for me
I also used risers bushings(rubber) to go between the detachable stuff and the bags for spacing to maintain the detachable sissy bar set up. Also to help with vibration.
painted the frames black. and the connection for sway black too.
still need to figure out a good gasket set up for moisture and to get rid of lid vibration
mine have the rails that go with the bags. so they now have holes buzzed out at the proper spacing so 3/8th hex bolts will go through the fender and attach with the stock connections the street bob came with.
so basically , just mounted the bags on the rails. buzzed out holes for the struts to line up with the rails. put my quick detach goodies in between the bags and the struts. and used rubber riser bushings in between the bags and the detachable metal pieces.
tightened it down and have a u support to prevent sway.
bags rails, u bracket, bolts hinges and locks. other than the rail supports that go on these old bags. everything else was from the motorcycle nuts and bolts pile I have. i thought i would need easy brackets too. figured I would give it a try first. glad I did
