Dyna power tie in for radio
Old 02-24-2012, 05:53 AM
LarryLives's Avatar
LarryLives
LarryLives is offline
Default Dyna power tie in for radio
Hi all.
Adding a radio to my Dyna.
I know most do it without upgrading anything. But if you have added a radio to your dyna where did you tie in for power?
I'm thinking running from my electrical box off a keyed power source and running a power supply under the tank to the front end.
If you have been thru this before please post what method you used.
Thanks
Old 02-24-2012, 06:49 AM
1HD1C's Avatar
1HD1C
1HD1C is offline
i have to check my manual but i thought there was 1 keyed and 1 constant
port under the seat to plug in to.
Old 02-24-2012, 07:44 AM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Originally Posted by LarryLives
Hi all.
Thanks
Jay,
Not that I've installed a radio on my Dyna but did it in my car.
Some radio's have two wires that have to be connected to a 12 V power source:
radio's red wire runs to ACC switch controled power in car
radio' yellow wire runs to constant power (for radio memory purposes) in car
According to the wiring diagram I have in my database, your 2006 FXDWG has an accessory plug underneath the saddle. It's a four pin connector.
pin 1 and 3 are accessory switch controlled power lines, pin 4 is ground.
If your radio needs constant power here's how I would connect it (see image):
option #1:
yellow to blue/gray wire at first fuse box connection "A" or "C" or to the hot wired B+ connector (not fused!!) using the H-D adapter harness (link)
red to pin 1 or 3 at acc plug using a Deutsch connector (link)
black to pin 4 at acc plug using a Deutsch connector (link)
option # 2:
yellow to pin "A" at first fuse box
red to pin "S" at second fuse box
black to a ground bolt at the fuse box or "-pole" at battery using a ring terminal
Edit: I added the B+ hot wired plug to the wiring diagram
Old 02-24-2012, 08:56 AM
pontiac69's Avatar
pontiac69
pontiac69 is offline
on my 11 wg there is 2 plugs under the seat. one single wire that is battery positive and the other is 4 wire plug with 2 keyed positive and ground wires. i bought an adapter from harley so i didnt have to cut any of the original wires on the bike. see pic for plug i bought from harley. it was an accessory plug for a touring bike. if you ask for the accessory plug adaper for a dyna, they give you the plug for battery positive. i used 1 circuit from that plug to run an amp.
Attached Thumbnails Dyna power tie in for radio-p3160095-1.jpg   Dyna power tie in for radio-p3160097-11.jpg   Dyna power tie in for radio-p3160097-1.jpg   Dyna power tie in for radio-p3160098-1.jpg
Old 02-24-2012, 09:22 AM
Mr.Guns's Avatar
Mr.Guns
Mr.Guns is offline
I just wired in an amplifier, straight to the battery, and connected the remote wire to one of the key-on wires.
Old 02-24-2012, 09:31 AM
FXD2003Rider
Default B+ hot wired plug
Yep, you're right! That plug is called the B+ plug and is "hot wired". I added this plug to the wiring diagram in my previous post. Attention: this B+ hot wire is not fused!
Here are two older posts covering the connectors subject:
Originally Posted by FXD2003Rider
MoCo has two types of plugs available (see image below):
70264-94A is connected to the gray/green Acc plug (powered by the acc switch)(#3 in image below), 70270-04 is connected to the gray B+ plug (hot wired) (#2 in image below)
Here's a parts list (H-D & Deutsch) & wiring diagram using a 4-pin Deutsch female connector to make your own GPS connector for the Cust Acc plug...
Old 02-24-2012, 09:44 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
depends on the radio, you can hard wire in the power and neg and then tap the remote line off anything that turns on and off with the bike. i tapped mine off the tach ligh
Old 02-24-2012, 09:45 AM
FXD2003Rider
I guess you added a fuse holder to the line that runs to the battery?
Old 02-24-2012, 10:16 AM
Mr.Guns's Avatar
Mr.Guns
Mr.Guns is offline
Yup, with a 10A fuse... Tucked everything in, can't see any of it.
Old 02-24-2012, 10:28 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
there is a inline fuse yes sir! have to have that!!!
Quick Reply: Dyna power tie in for radio
