Alternate Tires for the FATBOB
#41
Tomorrow I can post a Pict. of the bike, I think or you can Google the tire and get an image. Chapparal sells them, as does J&P. I think they are listed for V Rods. They are Z rated. My last set lasted as long as the dunlop and handle way better.
#42
#43
#44
It looks like the HD Tri-bar light
68546-09
I have the Avons and the grip like CRAZY, but they are going to be less then 10K miles tires (for the rear at least).
Another thread has a few guys running the Michelin Commander IIs. They are "supposed" to be double the average life of a cruiser tire. I will wait and see how they like them after a while
68546-09
#45
I am new to this forum. I havent even set up pics of my ride. But I have a question that I havent been able to get solid information on. Can we put a 200 60 r16 on the rear of a fat bob that has a burley slammer kit on it? I know the local dealership will frown upon leaving the factory 180 70, but I think a 200 60 would look much nicer. If anybody has done this or seen it done, please share. thanks
#46
The other issue is the stock rim width is 5" for the 180mm tire and the 200mm tire recommends a 5.5" rim - yes the tire will fit but not correctly http://www.sportrider.com/does-size-matter
The Avon 200 rear tire should fit without any modifications from what I read, but it's a tight fit, as will the matching front 150 tire.
TomBe (09-28-2020)
#47
I am thinking about new tires, the Avon Cobras to be specific. I was just wondering what the benefit is to get the 200/150 set up vs stock size? Is it just cosmetic for people or is it handling? I figured the fat bob already has wider tires then most bikes, so why do it? Just looking to get the best performance.
#49
The answer is yes and no - all tires are not the same width even if they claim to be - IE some 200mm tires may be only 196mm - like these Avon for example. http://www.avon-tyres.co.uk/motorcycle/cobra
#50
talked with metzeler tech dept on last friday. about when the new 888 would be out to replace the 880 in 180/70r16 saying next year. and told me to do the upgrade to the ME 880 200/60r16 its a v rated tire and its made of a softer compound than the 180 which is H rated more contact patch surface and will hook up better than the 180. and it will fit fine on the stock rim and no clearance issues on bike.
Bob
