Why brake rotors say "except 06-07 Dyna?"
Old 02-29-2012, 04:11 PM
macnab_sf's Avatar
macnab_sf
macnab_sf is offline
Default Why brake rotors say "except 06-07 Dyna?"
What's so unique about the 06-07 Dyna that causes rotors like these not to fit? I checked the part number on the 2009 street bob and the OEM front left disc is the same as the one on the 2006 street Bob. Do these guys mean it won't fit any laced Dyna 06 and newer? or just something about 06-07?
See the disclaimer here:
ebc-5-button-front-wide-band-brake-rotor-harley-davidson-big-twin
Thanks.
See here where what I think is the same rotor is listed as OK for an 08-10 Bob, but not for 06 or 07.
EBC-5-Button-Front-Brake-Rotor
I am looking for a five-point star-shaped floating rotor for the dyna laced hub. Not sure why it is so hard finding one.
Old 02-29-2012, 05:28 PM
DCLXVI's Avatar
DCLXVI
DCLXVI is online now
I know the brake pads are different and IIRC the rotors are too. '08 and newer are floating rotors. The axle diameter is different also but I don't think that matters.
Old 02-29-2012, 06:35 PM
macnab_sf's Avatar
macnab_sf
According to Ronnie's the brake disc didn't change when the caliper changed in '08. Caliper changed in 2008 ,but HD used the same disc until 2010.
Rotor assembly: 2006, 2007, 2008, 2009,
42040-06
Rotor Assembly: 2010, 2011
46717-10
Old 02-29-2012, 08:14 PM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
My 07 came stock with a floating front rotor. Back isn't though.
Old 02-29-2012, 08:34 PM
baldric's Avatar
baldric
baldric is offline
Received 3,094 Likes on 649 Posts
They probably don't make that "Your brakes are dragging" sound we have all come to expect on our Dynas if used on those years.
Old 02-29-2012, 08:35 PM
macnab_sf's Avatar
macnab_sf
Old 03-01-2012, 12:55 PM
revitonup's Avatar
revitonup
revitonup is offline
42040-06
46717-10
Does anyone know if the 2010 front rotor will work in place of a 2006 rotor? I bought 2010 SB rims for a 2006 SB and was just going to use the newer brake rotors with the stock calipers. The rear rotors have the same part number but the fronts are different. Will they interchange?
Old 03-01-2012, 01:27 PM
nkauf21's Avatar
nkauf21
nkauf21 is offline
Thanks.
It's because the rotor is 11.5". The front Dyna rotors on the '06 and up bikes are 11.8".
Old 03-01-2012, 01:31 PM
07bobber's Avatar
07bobber
07bobber is offline
in 2008 they changed the size of rotors to match the new calipers that also came out in 2008
98hotrodfatboy
EVO
20
01-02-2018 11:06 AM
619DYNA619
09-15-2016 06:39 PM
thunderroad1
04-25-2014 08:20 AM
harley50
08-05-2009 06:11 PM
icecaps
09-25-2008 12:40 PM
Quick Reply: Why brake rotors say "except 06-07 Dyna?"
