my new back tire is leaking around bead on mag , i dont want to pull tire again . is there a good product to fix this or do i just need to pull tire and clean rim ?
Mark where its leaking and just pop the bead at that spot. Might just be a little piece of trash right at that spot. Dont use fix a flat or some **** like that. It might fix the leak but it will throw your wheel out of balance. Its a new tire. Do it right.
true and id like to get a few years out of this tire , just dont want to pull it but guess i have to
You might not have to pull it. Just get the front end off the ground, deflate the tire and push the bead back where it is leaking. Even if you want to clean the whole lip of the rim there really isnt any need to take the tire completely of the rim, ya know? Either get some tire spoons or a big C clamp and two little blocks of wood will do the trick.
