Poor Mans Stage 1,No Tuner Or Download Needed
This combo is for the rider who just wants a good running and sounding Harley. I have no plans for any other engine mods so this worked for me : ScreamingEagle 2 slipons with the baffles taken out,the fiber wrapping discarded and the baffles reinstalled. K&N factory replacement filter,it flows all the air a stock 96 inch motor needs and you don't have to worry about rain or washing your bike or ever replacing it. Nightrider xied's,the small amount of extra fuel added at less than half throttle helps to cool the engine and throttle response is improved. That's it,I bought the slipons used so for $250 total I have a stronger,smoother,cooler running bike that has a deep tone but it's not overly loud. Oh yeah,guess I was lucky there's no decel pop either.
This is basically what I did when I had my Sporty...SE race application slip-ons (bought used off CL), SE breather kit & XiEDs....ran like a champ & no decel popping & plugs looked good.
Went SERTPRO & dyno tune with my Dyna, but the above is a much cheaper option for those on a budget like you said & while not optimal, will be much better than stock.
The K&N filter is less restrictive than the stock filter,you will feel the difference. I did the slipons and xied's first and noticed the bike felt stronger. A couple of thousand miles later I installed the K&N,once again the bike felt stronger,especially in the midrange. I'm not talking about big gains here but there is definately more power and better throttle response.
If you don't actually change the air cleaner back plate and just swap the filter out with the K+N it should be OK,
But if you change the back plate your best with a tuner.
Slip-ons don't make any difference in the flow with stock headers.
I had the 1.75 rush slip-ons and just the K+N air filter and Xieds to start it was OK a little decel but OK.
When I switched to 2 into 1 exhaust and the K+N back plate and filter it made a whole lot of difference going to a tuner.
