Oil Change
Old 05-01-2012, 05:19 PM
John D's Avatar
John D
John D is offline
Stage II
Default Oil Change
When changing the oil in my wide glide I have a very hard time getting all of the oil out. Any idea why?
Old 05-01-2012, 05:42 PM
michaelmitt's Avatar
michaelmitt
michaelmitt is offline
Wink
loosen and remove the drain plug on the oil pan.... this should help
Old 05-01-2012, 07:50 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,281 Likes on 2,349 Posts
Did you pull the dipstick out prior to removing the drain plug. You are removing the one closest to the jiffy stand, right?
Old 05-01-2012, 08:09 PM
Puffdaddy's Avatar
Puffdaddy
Puffdaddy is offline
Also warm up the engine prior to draining
How do you know it isn't fully draining? It won't take the full capacity on a "wet" change
Old 05-01-2012, 08:12 PM
Billyram's Avatar
Billyram
Billyram is offline
I've found with the bike sitting straight up in a wheel chock more oil will drain out. You do have to remove the dip stick on a dyna.
Billy
Old 05-03-2012, 09:54 PM
John D's Avatar
John D
John D is offline
Stage II
Thanks for nothing wise guy.
Old 05-03-2012, 10:00 PM
TyeAdair's Avatar
TyeAdair
TyeAdair is offline
Be careful what you say about lube jobs, there are some touchy people here.
bubdifab
07-17-2013 06:52 PM
keeferfish
Oil Archive (no new posts)
15
08-04-2011 08:50 AM
rynegold
06-20-2011 07:08 AM
bL33d
08-06-2010 10:11 PM
huntinjoe
05-21-2007 12:19 PM
Quick Reply: Oil Change
