Question for you guys with XIED's
Old 05-10-2012, 09:39 AM
Kevinmach1's Avatar
Kevinmach1
Kevinmach1 is offline
Default Question for you guys with VIED's
For you guys with the VIED's, if you have the one with the adjustable dashpot. Where did you set your initial setting? And where did you end up with the setting that worked the best?
Thanks...Kevin
Old 05-10-2012, 09:42 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
XIEDS are simply an inline resistor, in basic terms. There is not adjustment as far as I know.
Old 05-10-2012, 09:54 AM
cturner's Avatar
cturner
cturner is offline
I beleve he is referring to vieds..
Old 05-10-2012, 10:05 AM
wyldspirit's Avatar
wyldspirit
wyldspirit is offline
Cturner is correct. The xieds are not adjustable whereas the vieds are
Old 05-10-2012, 10:10 AM
Kevinmach1's Avatar
Kevinmach1
Yes, you are right. Vieds.
Old 05-10-2012, 10:41 AM
cturner's Avatar
cturner
cturner is offline
I had them on my bike and to be perfectly honest couldn't tell a difference in the adjustments, so I just ran them about 75%. Bike did seem to be somewhat cooler.
Old 05-10-2012, 11:18 AM
Foxster's Avatar
Foxster
Foxster is offline
I'd suggest a little caution with Vieds. Xieds were designed to bias the O2 sensors just at the limit of their operability, about 800mV or an AFR of about 14.25:1. Go beyond this with Vieds and the life of the O2 sensors will be shortened and their output will not be accurate.
Old 05-10-2012, 11:23 AM
ndrmills's Avatar
ndrmills
ndrmills is offline
14.0 on my WG... Ness Big Sucker and V&H Baffle swap and a skinned CAT.... Runs much cooler and sounds oxcum....
Old 05-10-2012, 11:33 AM
ndrmills's Avatar
ndrmills
ndrmills is offline
This is true Fox.. But for me I would rather replace a O2 sensor over a burnt piston or two...
Old 05-10-2012, 12:33 PM
Ovaltine Jenkins's Avatar
Ovaltine Jenkins
Ovaltine Jenkins is offline
I agree. It should be noted that if (or when) the lambdas become inaccurate, it's almost always in a direction which causes the engine to run leaner, eventually eliminating the benefit of the mod, and potentially taking you into leaner-than-stock territory.
Quick Reply: Question for you guys with XIED's
