08 Dyna Fat Bob Oil Change
Hi everyone. I bought my Fat Bob used and it didn't come with an owners manual. I feel I've done an extensive search yet I still have questions about doing an oil change on my 08 Fat Bob. The videos on Youtube seem to skip the primary oil as well as not mention how much oil is used. I know where all the fill holes and drain plugs are...So my question.
When doing an oil change, is it required to change the primary as well? I mean, is this usually how it's done or are they done at seperate intervals? All mention of oil changes and primary seem seperate.
Also, am I correct that it's 3qts in crank and 1qt in primary?
Sorry if I'm asking a dumb question, and I am planning on getting a service manual asap so no need to suggest it. Thanks for any help.
Oil change is listed at 1000, 5000, and every 5000 thereafter. The Primary is every 10,000, so it isn't necessary to do both at the same time.
These are guidelines, and many follow what they feel is best for their bike (more frequent can't hurt, less often with Synthetic, yearly, etc).
As far a the capacities, the primary is about right at 1 qt.
The "wet" fill on the crankcase is more like 2.5 qts! Start with 2 then add as needed. I doesn't matter how you try, you won't get it all out, so 3 will overfill
What puffdaddy said + the tranny oil whenever you change the primary. tranny and primary take 1 quart each. Don't be surprised if your primary oil is gray especially if it has been ridden hard. tranny oil should come out as clean as the day it went in. Do yourself a huge favor and get the HD manual for your year/bike.
here's a picture of what it looks like inside the primary chain case. The green line represents where the bottom of the derby cover opening would be and the red line is where the oil level goes to. The bike is on a stand in the air and the bike isn't level, I think it would probably be better to fill while both wheels are on the ground.
