Rinehart 2-1 Install Problem
Hey guys - I pulled the trigger on the rinehart 2-1 exhaust. Well, the ***** didn't bother including the installation instructions in the box.
Can someone help me - first of all, the muffler hits the axle nut big time. I have all four cylinder nuts loose as well as the two muffler nuts. Second, with the James exhaust gaskets, what is the exhaust nut torque supposed to be?
Thanks!
Thanks!
Thanks, but, right now the "head" of the axle is on the RH side; it extends about .7" from the swing arm. If I swap it around then the "nut" end of the axle will be on the RH/muffler side; it extends out about 1.5".
If your reinhart muffler was really hard to push into place like my bubs were it may be that your muffler is just out of line with the collector pipe. Loosen the big stainless steel clamp between the two and wedge the center in with your foot.... if that is the case?, hard to tell without a pic.
gant
04-13-2013 11:07 PM
