Just got my new wide glide today and installed Big Radius 2-2 and a Roland Sands Air cleaner. I am getting some decel pop in every gear. Should I download a new map to my PCV? I have checked the exhaust port for leakage already. Thanks
Ok so I messed around with the map for my BR 2-2 and Roland Sands Air Cleaner. Made it more rich in the 0-5% throttle and 1250-3000RPM Range by adding 5, 7, 9, 11 progressively. This ended up flooding the engine and the decal pops were still there. Anyone with any advice? Should I try leaning out the band slightly in the lower throttle ranges. BTW I have never done this before so any advice is good advice.
Identical problem here with SE stage 1 and V&H Staggereds. Even the dealer standard down load did little to stop the decel popping. I spoke with a Dyno shop and he confirmed a tuner would fix it. I plan on getting the SEPRT and change the exhaust to a Bassani Road Rage meg long.
Bob
Sounds as if your getting popping in each gear decel? Sounds like you need to lean out by 5-7% and decrease richness in the same amount. Give it a chance to correct from there.
