Whirring noise
Whirring noise
About two weeks ago I replaced my inner primary bearing with the high torque bearing from Baker Drivetrain because I had the metal roller skate noise that stopped when dropped into gear. All was good and quiet for a couple of weeks.
Now I have a whirring sound from the primary area that is hardly noticeable at idle, but speeds up with engine speed. I can hear the noise increase until I up shift, at which point it gets quieter, then it starts to get louder as I accelerate.
If I pull in the clutch while going down the road and let the rpms drop, it goes away, but as soon as I engage the clutch it comes back. Unlike the IPB noise, it doesn't stop when dropped into gear.
Well, I pulled the primary apart, and I checked everything out. All looks good. Chain was not overly tight. I put it all back together filled it with Bel-Ray primary oil, and the noise is still there. It must be engine noise though because the primary looks great.
I'm going to keep riding it until something gets worse or blows up. I did switch from Amsoil to Mobile 1 on my last oil change. Is it possible that the mobile 1 is a little noisy compared to the Amsoil? If that's all it is I'm good.
RPDLV
11
05-30-2019 10:23 PM
Wakko47
01-17-2014 12:01 PM
