how to adjust belt tension and align wheel???
The owners manual will tell him to get a 1/4" piece of welding rod and fit an o ring onto it to check alignment using the holes drilled into the swing arm and inside circumference of the axle. Yes, this is the owners manual these clowns swear by, with it's 22-65 lb ft tq values and all. Lmao.
There I got a band aid for my finger!
There is more than a couple pages of explicit instructions in the SERVICE MANUAL on proper alignment and belt tension. Even gives pretty pictures to make it real easy.
Again, forgive me lord of the SERVICE manual for my negligent use of verbiage
Pardon me for the improper verbiage. Same thing. See, you're one of the people I was speaking of. You purchase a $13,000 plus motorcycle and they cant even put a guide on the adjusting blocks/swing arm. No, they tell you to use WELDING rod and give you tq values that range 40 lb ft. I'm just saying this service manual bible is not all its cracked up to be.
Is there something wrong with using a piece of welding rod to make a tool?
I don't know what you are reading but this does not look like a 40 lb ft range to me: Tighten axle nut (2) to 60 ft-lbs (81.3 Nm).
Dude, you have no idea who I am, so STFU with your stupid generalizations.
Keyboard cowboy....
