Inner primary service bulletin
Yeah Mud, the inner primary is toast. It's just starting. Looks like the classic lube starvation scarring. Lock ring was positioned properly, so that rules that out as cause of damage. I'd take a picture of the damage, but both my digital cameras are pissing me off this morning, and I need to get to work. I'm wasting daylight screwing around with this thing.
Service bulletin. I tried the search, no luck.
Does anybody here have a copy of the service bulletin on the inner primary troubles??? Or a link to it?? I'm fixing to take this bearing to the dealer, and try and get them to give me one under warranty, and you know they are going to say, "bearing failure?? what bearing failure?? we ain't heard about no bearing failure."
RE: Inner primary service bulletin
That's nasty. I guess it's an 06 Dyna as I remember hearing about this issue... your dealer would even think of doing that with you doing your own work?
I don't have a copy, but you may find it here... tons of info
http://www.harleyhog.co.uk/
Check your owners manual. There was an addendum to the manuals that the MoCo sent out which specified the replacement of that bearing at 15,000 miles at the expense of HD. The MoCo than sent out a letter stating that repair was no linger necessary. How many miles do you have? What type of oil are you using? That is an INA bearing and at the least HD should give you a new one for free. Was there any other damage from debris?
I found my letter from the MoCo which is from Steve Phillips, VP Quality and Customer care which specifies a lubricant change for the primary and transmission at 1,000 and every 5000 miles plus replacement of the inner primary bearing at 15000 intervals. This replacement will be done by HD at no cost. If you PM me your fax number or address I can make a copy and fax it ormail it to you tomorrow when I get to work. KB
Im kinda courious about this issue especially since I have an 06 Dyna myself. Since the 07 Touring models are now similar to the 06 Dynas, are people having the same problems with them? I'm wandering if H-D upgraded the bearing in all the new 07 models or will be seeing the same type of problems with the 07 models as well? I'm planning on ordering me a new 07 Road King in the next few weeks,but not if they potentionally will have the same bearing problems as the 06 Dynas.
John
John
I think they put a higher capacity bearing in the 07 trans. I'm sure that INA has to eat at least 1/2 the warranty on the 06 returns so they would have spec'ed a better component. But I am still using synthetic lube in the primary & trans and following the original 5000 mile oil change suggestion even though they sent another letter out stating 15000 was ok. I think they just have X number of units out there that will fail so they probably figure to just fix those and move on. The guys who didn't get a bad bearing won't show up for a fix. Much cheaper than a recall.
remember reading about this here on the board some time ago. seems the early '06s had the problem and the later was supposed to be fixed. I have a late production '06 (May) that did not have the addendum included in the owners manual. have about 3000 miles with no problems. changed trans oil at 500 and 1000. now running Redline shockproof.
[IMG]local://upfiles/12616/D9B22CBD7DA7410B8117A857A10D23B9.jpg[/IMG]
