Twisted 12mm Spark plug wires
Here's what nightrider.com (the makers of Xieds) think to plug leads. Scroll to the "Claims of Horsepower Gain" section.
http://www.nightrider.com/biketech/truth.htm
The bottom line is that plug wires do not add HP. However, if you have a fault with your old ones and they are breaking down then you can be losing power. Fitting some new ones will restore this lost power but it won't matter if the new ones are stock ones or foot thick ones that cost $/£1000.
Its like spark plugs. There's an awful lot of money to be made from them and an awful lot of bullshit claims about them. Bottom line though is that the leads are a bit of insulated wire and plugs are an insulated bit of wire and an air gap to ground. If the stock ones are not faulty then they are working as good as any will.
Thanks Foxster. The article provided has succeded in expanding my knoledge on this system. The author seems to know what he is writing about ( atleast to a layman ). Even though he could improve his writing skills. I think that there is always room for improveing OE systems though. Certainly manufacturers can't afford to use the best of every component available and still be cost competative. Aggread that the OE systems are adiquit enough to to the job. And, aggread that improving these systems will have little bearing on Horse Power gains and such. But every improvement on individual systems makes an improvement on the overall system. So the real bottom line is: where do you want to spend your money.
Unless you use ACCEL plug wires that throw check engine codes for no good reason. I asked about Twisted's a while back, and I had to cringe at the fact that I was gonna miss out on 50% more HP & TQ, I went with the Orange SE. I suppose if I had got them, I wouldn't have to get a Big Bore kit.
I bought them for looks only, because for all the other components you have, you are not going to see any gains from different wires... unless you change the coil and plugs as well... and they just don't make that high end of replacement stuff for those components.
I use the 8.8 mm Drag Specialties wires with new stock plugs.
no codes and runs great.
Price is OK.
http://www.ebay.com/itm/8-8mm-SPARK-...ht_2667wt_1344
Price is OK.
I know this is a an old Post.
But I have a 91 FXLR Screaming Eagle everything including the Ignition, Coil and Wires. The Bike is a horse, it will kill a Crotch Rocket in a heart beat.
I bought the Twisted and the Power was amazing, it was very noticeable and that's an under statement.
I also run e3 Spark Plugs.....the power Twisted delivered from the Coil and MPG was unbelievable.....!!
Well worth the money....!!!
and above poster your 91 SE FX will not KILL a rocket... i have a GSXR 750 and 1000 and i can smash on buddys running 120r motors, 124 stroker motors and NOS... different kind of bikes man. that is flat out fact, look at HP to weight and lets be real... maybe the 500 and 600's you can play with, but bigger rockets, no way...
