Are those jokers machine a plug n play or did you have to cut factory wiring?
How bright are they?
do they work as running lights as well or just blinkers?
Yea if your were doing both you would need to relocate. But since you just want to put the right on the left, go to Lowes and get a bolt that's the same length going through and mount the signal to that.
Thanks
i cut wire, i have them set up as just blinkers, although you can get a relay from Badlands to make them both running and blinking,,, they are much brighter than a standard stock set up.............
I did it to my 2012 street bob without relcoating my turn signals. I bought hd's mirror extender. On the right side I found a black spacer laying around the garage that was about 1/4" and put that between bracket and mirror To give room for signal. It's tight but you can do it without relocating, or my spacer lol. The turn signal may look a little special without some kind of spacer.
