Can't decide which cam? T-Man 625 or 590
Old 08-13-2012, 07:56 PM
ReapersWG's Avatar
ReapersWG
ReapersWG is offline
Exclamation Can't decide which cam? T-Man 625 or 590
Well I've narrowed my choices to these two cams. I'm currently running a SE Pro Stage 4 103 which is the 2010 kit with the SE 110+ heads, 58mm TB, 10.5 SE high comp pistons, 260 cam along with ACRs 2 into 1 FatCat with big boar baffle and SE Heavy Breather. At first I loved this kit mainly because its a big kick in the pants from a stock HD but even after my tune I knew I wanted a different cam. The 260 hits way to late even for a lighter bike like a dyna IMHO. From what I've found these two cams will move my TQ around 2500 to 2800 with the 590 hitting closer to 2500 or less and both seem to carry the HP out thru 6000. So has anyone used this cam in a similar setup and if so what can I expect. Thanks for any and all replies
Old 08-14-2012, 12:13 PM
ReapersWG's Avatar
ReapersWG
No one running either of these cams.......help please
Old 08-14-2012, 04:50 PM
denimbob08's Avatar
denimbob08
denimbob08 is offline
have not heard about those cams. but f your not dead set on those check out the fueling reaper 574 cams. after all my searching those are the ones im getting. broad curve and right where you need it and use it. they also have a bigger one. 630 i think
Old 01-21-2013, 06:29 PM
hogzeke's Avatar
hogzeke
hogzeke is offline
Was wondering i have the same setup but in a 09 rglide if u put either one of the cams in and how does it feel
Old 01-21-2013, 06:40 PM
JonnyIndy's Avatar
JonnyIndy
JonnyIndy is offline
I've got a similar set up and am running a woods 631 cam. Works great IMO
Old 01-23-2013, 11:04 PM
Dyna_in_the_works's Avatar
Dyna_in_the_works
Dyna_in_the_works is offline
T-man 662-1 cams here... love em. Called them myself, they recommended that one from the get go.
Make great numbers, rides amazing, throttle hits like a hammer.
Build is in my sig pic.
Old 01-24-2013, 04:20 PM
Dyna_in_the_works
Do you already have those heads?
In my very humble opinion the 590s are a little timid for that setup if you already have the heads.
Superglide2012
05-01-2015 04:12 PM
Mr D
2014-2023 Touring Models
14
06-11-2014 02:30 PM
BIG THUNDER
02-08-2012 04:52 PM
ElectraHead
02-17-2011 09:53 AM
hadlje
05-20-2009 12:37 PM
Quick Reply: Can't decide which cam? T-Man 625 or 590
