Part # on a wrench to adjust the steering nut??
I used a steel punch and just tapped it to turn it. I followed the procedure in the manual. You have to loosen the pinch bolts on one of the trees and the stem nut too, if I remember correctly. Then adjust the nut, tighten the trees, tighten the stem nut to torque spec, then check the fall away.
