installing mid controls
Hi everyone, I currently have the stock forward controls on my 2012 wide glide, I am hopefully trading them for mid controls off of an 09 super glide from a fellow forum member. Does anyone know if they will fit? And if they will will anything else be required for install?
Like already mentioned, not as easy as just swapping pegs and linkage. You need the inner and outer primaries from a mid control bike. That involves removing primary drive/clutch and starter sprag. Have you considered getting the Dyna footboard kit? It's the footboards kit that comes stock on the switchback. It's in between mid and forward controls and you won't have to change a thing on your primary.
Ya, the kit will fit on any dyna. If you have mid controls you have to take the shifter shaft out of the primary and cover the holes. If you already have forwards all you're doing is changing the shift linkage rod. The boards mount to the forward control and mid peg mounts.
Concider boards??
As mentioned your 2012 WG came with forwards from factory therefore doesn't have the hole in the primary (inner or outer) for the shift shaft. So you would need to replace both.
Another option would be boards. Here there are two options. Board kit from HD who's is same as SwitchBack, or aftermarket which is exactly the same as the old (pre06) Dyna Defender (FXDP) boards with the exception they have a boss intricated for the forward shift shaft.
The SwitchBack boards mount further forward the the old style which you may not like.
I've got the old style on the wife's low rider and we both like position over the SB.
Check out eBay # 380706718295
