Please Help--Messed up Grip Install
Sorry for the newb questions. Feel free to laugh or poke fun. I have never worked on bikes before.
I tried installing new grips today. I did consult the service manual. Unfortunately, the job I did sucks. I put the grips on the left--no problem. Easy as cake. The right grip caused me to totally mess up the throttle cables. I don't what gives.
I started accroding to the instructions in service manual. Let out all slack in both idle and throttle cable by looseining nut. Popped out the ferals from the stock throttle. Removes grip, put new grip into bar. It took some doing but I got the ferals on the end of the cable to pop in. Unfortunately, there is now a lot of slack and it looks like the ferals bob up and down inside the slot when the throttle is twisted. They get jammed on the housing when it is closed. I followed instructions to tighten the throttle and idle return using the cable adjusters. They never seem to pop back all the way ebcause of the rising feral pin. The best I could do was get it so it popped back almost 90% of the way.
I don't know what to do. I hope I didn't screw up the cables or bend something. I tried resintalling the stock grip and the same thing. Ferals bob up and down in socket when it is pinned into the slot.
Thank you for any advice or assistance.
Open the adjuster on the throttle cable until the slack is gone. Adjust the idle cable, ( ferrule closest to you when in the seat,) until most of the slack is taken out. ( This one should not be "tight", a little slack is good.)
Start the bike, and turn the bars lock to lock. If the idle stays even, you're done. The grip should fall back to idle immediately when released.
[quote=Stiggy;10336060]Open the adjuster on the throttle cable until the slack is gone. Adjust the idle cable, ( ferrule closest to you when in the seat,) until most of the slack is taken out. ( This one should not be "tight", a little slack is good.)
The problem is there is slack everywhere. It doesn't matter how much I adjust the throttle adjustment cables/screws either way. It gets to a point where it remains limp and lifeless.
I will try to do some more in the AM. I am just furstrated to the max. I thought I was fairly good with working on autos and such. I guess have a lot to learn when it comes to bikes.This just doesn't make a whole lot of sense. Followed the service manual instructions to a tee. Even consulted a youtube video on a harley cable adjustment and did same exact thing. Can't take up slack.
