18" apes
18" apes
i have an 07 streetbob with mini apes from harley, i've put 18" ape hangers on, does anyone know what length clutch, acelerator, and brake line i will need, can you just add the difference between the mini apes an the 18" bars an add that to get the new cable lengths? thanks for any help
Some old notes I found from my bar replacement:
Stock Street bob cables are:
Throttle/Idle 32.5"
Clutch Cable 68.69"
Brake line about 47"
The stock mini apes are are 10.5", so given the 7.5" increase in height and any additional width, I would go with 40" throttle/idle, 76" or 77" for the clutch, and 54" or 55" for the brake line.
Check out Jireh Cycles for good cables at a great price. You can also get Russel brake lines there. Good luck.
Throttle/Idle 32.5"
Clutch Cable 68.69"
Throttle/Idle 32.5"
Clutch Cable 68.69"
Throttle/Idle 32.5"
Clutch Cable 68.69"
Brackneyc
12-07-2007 08:58 PM
