Harley quick connect disconnect sissy bar(cant disconnect) help!
Well its been a while since iv taken them off-
the one side disconnects fine- however i piushed the small pin in that sits inside the black bracket and i am pretty sure i locked it or something-
picture 1 shows the black connect-
picture two shows in side the black connect where that pin is-
any help. thanks-
any help. thanks-
Ok... did some searching and found this-
If there is a locking device on it, instead of the black ****, there should be a round key type of hole on the top. you'll need the key, as all are different, insert the key and turn it. There will be a little round metal rod that is spring loaded, and will pop up.....
I got no key.!
any thoughts?
I got no key.!
any thoughts?
