I have an 01 super glide that I just replaced the cam cover and clutch release cover. Adjusted the clutch cable after and now the clutch is not engaging. The bike was running fine. Any ideas of what I need to do?
I would bet something in the clutch release cover is not correct. If you have checked everything else then pull the cover as something is a miss in there.
Check to see if your clutch cable isn't caught in the lever housing holding it out of place. By clutch cover , if you mean on the right side of the bike where the cable goes in you may have dislodged the three ***** in there which you will now need to re-adjust.
