Raised white/red letters on tires
RE: Raised white/red letters on tires
Thanks man - I'm done w/ the coating; still have the black strut covers, heat shieldsand black-spring OEM shocks to put on and it is done. Not a big fan of chrome (just a splash here and there)and doesn't shine in my 'hood anyway. She is a true 'dirty girl'!
The risers are from Drag Specialties - 6" w/ hidden cap bolts - look great from the saddle. It a cold trudge to my shop to get the part #, sorry. Still need to switch out the cables - looks goofy but they work fine.
[IMG]local://upfiles/11891/455ED1A153D64CD892625521EBE5942E.jpg[/IMG]
[IMG]local://upfiles/11891/CC6766D864994C9FAB7D745F7A9B8351.jpg[/IMG]
It was a serious pain to do but I really liked it. I haven't done it on the tire I have now because it's old and it came on the springer. As soon as I pony up for a new tire, I will do it again on the new one.
You can obviously fill in the letters or do just the outline like I did. I figured I could always fill it in later so I started with the outline and liked it so I left it as is. The rear is a serious pain because you can't get at the whole tire. When I do my new front tire, I'll do the rear this time.
BTW, the stuff that the MoCo sells holds up very well.
Kevin
Kevin
ORIGINAL: steelcowboy
Just a tip I used to clean them with simple green and a scrub brush each time before doing it then would spray it with tire shine to sort seal it lso keep ing razor blade handy can help to clean up the edges.
Kevin
