"New" H-D 360® MOTORCYCLE OIL
I was on the H-D web site and read this
Harley-Davidson Motorcycle Oil is unlike off-the-shelf oils. H-D® 360 is a complex
mixture of carefully selected premium quality mineral oil and an exclusive
performance additive package (25% performance additives and 75% premium quality
mineral oil). Designed for maximum performance in H-D air-cooled V-Twin engines,
H-D 360 is a unique oil for a unique application.
What changed?
What changed?
According to this chap, the new formula has more polymer viscosity modifiers
http://www.highdeserthd.com/custompa...g=riderscorner
which according to this fellow, ain't a good thing in the long run
http://jerickweb.50webs.com/autobin/oil.htm
Well, might not be good for the longevity of your bike; should be very good indeed for getting you into the dealership to trade in the old, gummed up with polymers scoot on a nice new one ( be sure to only use genuine HD oil and lubes, the MoCo can't afford to have you running around on the same bike for the next 5 years).
Movr viscosity improvers means it will shear out of grade faster.
It means they take a thinner oil,a 20 grade in this case,add a ton of viscosity improvers to resists thinning when the oil heats up,but those viscosity improvers look like a coiled up snake. They uncoil when hot but will break while uncoiled(shear) which thins the oil when hot.
Do over time the oil shears back to the 20 grade it started as.
When looking at oil the viscosity index is a very important value. The higher the viscosity index the less an oil can shear. A straight grade 50 has a higher viscosity index than a 20w-50 even though they are both a 50 grade hot.
In summer conditions a straight grade oil flows great and will not shear so at temp the oil is exactly the right thickness. After even 1000 miles most v-twin oils will shear out of grade and be thinner than the 50 grade hot specified for the engine
Received 4,614 Likes
Honestly,I don't really know the answer to either question; sometimes I think the HD engineering department is comprised of one lonely, over worked schmoe who never gets invited to the office parties constantly being thrown by marketing and legal, which apparently, are very well staffed indeed.
Geoff1200 (08-16-2019)
