Crankcase breather install woes! Need HELP!
Wow, so I'm having a brainfart or something but i have a screamin eagle stage 1 a/c (circular type) and i just purchased a crankcase breather kit for it. only problem is that the breather bolts that came with the drag specialties c/c breather are too short. it's either this or the set of instructions worth using as toilet paper. the c/c breather is 2 breather screws, 2 banjo fittings, 4 step washers and 2 reg washers.
If what I am trying to do is right, the main problem would be the S/E back plate for the head mounts are too thick, thus the breather screw won't reach the fittings in the head.
ugh ****. Thanks for any help!
