2006 Speedo Wiring - Mini Speedo from Digital Help
Old 10-25-2012, 04:07 PM
Jason Bradford's Avatar
Jason Bradford
Jason Bradford is offline
5th Gear
Default 2006 Speedo Wiring - Mini Speedo from Digital Help
Hey guys-
First post for help but long time lurker!
I've got a 2006 Dyna Superglide Custom (FXDCI). After a summer of "re-creating" my bike I'm close to being done but am baffled re: the speedometer. I've searched the forums and ran across some wiring diagrams and such but nothing exact for what I'm hoping to do.
The former owner put on a Dakota digital piece that I didn't want nor did it fit the new bars. I decided to go with a mini speedo that would mount below the bars and be hidden (pic attached).
I ordered this mini from Demon's : Mini-Speedo It has 5 wires. I thought it would be simple... however, coming off the bike is 12 wires with 3 different harnesses (ones for the Dakota).
I tracked down a wiring schematic for the Dakota and by process of elimination determined what I thought were the correct wires needed. Wrong. I got power to the new speedo but nothing else. Also, have the manual with Speedo wiring diagrams to throw into the mix... still no help on this one.
I've determined that the speedo wiring is connected in the tranny not the front wheel.
The Demon's sites says that it'll work with Harley bikes... Attached is a screenshot of their wiring diagram. I've created flowcharts/diagrams and process of elimination trying every combo possible with no luck.
Any thoughts? Suggestions? Thanks in advance for any help!
Attached Thumbnails 2006 Speedo Wiring - Mini Speedo from Digital Help-screen-shot-2012-10-25-at-3.40.56-pm.jpg   2006 Speedo Wiring - Mini Speedo from Digital Help-photo.jpg
Old 10-25-2012, 04:27 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Perhaps this wiring diagram from my database will be of any help?
2006 Dyna Dom and Intl Models (Except FXDWG, FXD35), Instruments & Indicators
contribution of ackman1968 06-20-2010
Old 10-25-2012, 07:44 PM
Jason Bradford
5th Gear
Thanks! Actually used that diagram earlier. Very helpful (helped fix my rear blinker issues).
My issue seems to be determining which of the factory wires should be used with the 5 on the new speedo. The colors don't match up... Just not sure what signal is flowing on which wire and then where to connect to new speedo.
Old 10-25-2012, 08:05 PM
sonnydaze's Avatar
sonnydaze
sonnydaze is offline
3 wires go to vss other 2 are power and ground .
vss is on trani by starter ,wire goes up under seat
Old 10-25-2012, 08:19 PM
Jason Bradford
5th Gear
Thanks Sonnydaze-
What wire is the VSS on the stock diagram? Is that the same as the databus line?
Thanks again.
Old 10-25-2012, 08:33 PM
sonnydaze's Avatar
sonnydaze
i dont know , i have a 2001 fsm
Old 10-25-2012, 08:39 PM
sonnydaze's Avatar
sonnydaze
just looked at you schem its not the same
black pin 7 ground,
sensor out put pin9 w
12vdc r pin8
in my manual for 2001
so orange would be pin 8
green pin9
ground pin7
Old 10-25-2012, 08:43 PM
Jason Bradford
5th Gear
black pin 7 ground,
12vdc r pin8
green pin9
ground pin7
Ok- cool. gonna give that a shot and cross my fingers.
Thank you sir
Old 10-25-2012, 08:47 PM
sonnydaze's Avatar
sonnydaze
Thank you sir
no its not the same
Old 10-25-2012, 08:53 PM
sonnydaze's Avatar
sonnydaze
do you have the 2006 vss diagram ?
Quick Reply: 2006 Speedo Wiring - Mini Speedo from Digital Help
