FXDF Tires
FXDF Tires
Riders, I am confused about what to do when replacing tires. The rear obviously will need it first. I like Metzeler 880's. The rear of the specified size is a radial. Something tells me I should not mix radials and bias plys but the Metz website does not state that the replacement front is one or the other.
I see my possibles as mixing the Me880 radial rear with the stock front (option #1) Replacing both with radials at the same time (#2), or put a 180/65B16 on the back until they both need replacing(#3).
My only issue with #3 is that it will throw the speedo off and look like I am racking up miles quicker than I really am. Not being a mathematical genius I don't have a way to quantify how big of a deal this really is.
I would appreciate your thoughts. Thanks
I've been using the stock dunlop FB tires since the beginning and was kinda happy to replace them at lop-sided intervals since we always get a few more thousand out of the front, but at my next tire change they will both be due at the same time and i am going to go with michelin commander II, which are composite tires, just to see how they feel and if they last any longer. They are made with a harder gum in the middle where we do 95% of our riding and are softer on the outside for those low turns. Any other tires are just going to **** me off because they won't last as long, despite the safety of the added traction....... MY 2 CENTS
I've tried Dunlop's and Metz's and Avons and have to say I get more miles with the Avons than any I've tried. I put a Avon Storm 2 Ultra on the back last year and have 11,000 on it and maybe another 1000 before replacing it. The only problem I ran into was the lower profile Avon which was a 190/50-17 size. The 50 series threw my speedo off by about 7mph, which was no big problem for me.. My replacement tire this time is a 180/55-17. a little narrower and a little taller tire, but I expect to get just as many miles outta this tire.. Avons are good looking and grip great on flat and winding roads. I think the harder compount in the center is the key to more miles than the metz's.I'm sticking with Avons on my ride...
Yep there's the rub. I checked the Michelin website, and as expected the fitment charts don't list the FXDF. Odd bike to get tires for. Kinda why I listed the three options i did. If you opt for a 180/65 instead of the 180/70 that Harley calls for it automatically looks like the tire you chose is better because you are turning the odo over faster even though you have traveled the same distance in reality. Keep 'em coming, good stuff to think about. Thanks
As an additional note I used the interactive fitment feature on Metzelers' website. They suggested a bias front tire and a Radial rear. Sized the same as recommended by Harley. That seem odd?
