led tail light turn signal trouble.. help with wires
Here is what my system looks like wired up. My LED's one have two wires on them (Ground and Active). I ordered some True-Flex Dual Converters that take the wire setup on my bike from the 3-wire (Gound, turn and brake) to the 2-wire on the LED. Here is a pic of how my tail lights are wired, alone with the wiring diagram from the Dyna book. Hope it helps you out, good luck.
Run/Turn Only with side light for brake
Run/Turn/Brake with added side light for brake (my current setup)
Dyna Diagram
Dyna Diagram
motogpfan82
Electrical/Lighting/Alarm
06-09-2019 07:57 AM
koresample
02-09-2015 10:38 PM
